• Boating Goods
Boating Goods
Boating Goods
12v Galley Water Pump And Tap 4.3L Min
Store/Boat Deck Fittings And Hardware
SKU 00543
£44,00
  • 🌸 ENERGY-EFFICIENT & BEST CHOICE - Low Power Consumption(31Watts, DC12V/2.6A), High Performance(4.3 L/Min, 35 PSI); easy to install, easy to use.Ideal for marine, caravans/RV, and agriculture applications
  • 🌸 DOUBLE-SEALED - The diaphragm pump has sealed switch and coating to prevent corrosion, the body is sealed, to prevent incidental moisture and dust from entering. More resistant to corrosion and high temperatures. Safe and Durable
  • 🌸 AUTOMATIC STOP/START - The pump is responsive and runs smoothly. It has a built-in pressure switch which automatically starts and stops the pump when the faucet is opened and closed.Fast response speed and smooth operation
  • 🌸 SELF-PRIMING - It designs with the self-priming function to prevent liquid from backflow in the pump. The function allows it to be mounted above the water tank, Do NOT submerge it in water
© Boating Goods Report abuse
