• Boating Goods
Boating Goods
Boating Goods
Boat Cabin Ceiling Light Stainless Brass 12v Led
Store/Boat Electrical And Clocks Gauges
SKU 00418
£19,00
Finish
Ceiling light, 12 volts, with built-in switch. Material: painted brass. Lens diameter: 102 mm. Total diameter: 140 mm. Boat cabin ceiling light.
Description:
Scope of application: yacht / RV / bus interior ceiling, corridor decorative lighting, indoor underground decoration, turning and stair lighting
Stainless steel material shell,waterproof plastic lens, protection circuit and rust-proof copper wire
High brightness, high light transmission, long-distance illumination , and it is very energy-saving.
Built-in mini black rocker switch, handy to use
The warm white light color has the function of indicator light and can beautify the atmosphere.
The surface installation makes the product easier to stick to the surface of the object, easy to install and integrate the environment.
Specification:
Material: Stainless Steel Or Brass
Voltage: 12V 10W
Light Color: Warm White Light
Diameter: Approx. 138mm/5.4 inch
Package Includes:
1 Piece Ceiling Dome Light
© Boating Goods Report abuse
