A boat deck water filler designed to be installed flush on the surface suitable for 38mm (1 1/2") hose featuring a 'WATER' tag on the cap and a lifting toggle handle for opening and closing.
The screw cap has a toggle in the top to help when twisting open or closed and the cap is secured via a wire to the filler unit to prevent losing the cap in the water. This wire is fitted through a bracket so it compensates for the rotation of the cap when opening and closing so not to knot the security wire. the water filler cap with toggle handle is the replacement cap should you lose it overboard!
This flush deck filler has four counter-sunk fixing holes which help to ensure a secure fit.
85mm overall diameter, with 57mm filler base diameter.
