• Boating Goods
Boating Goods
Boating Goods
Boat Launching Wheels For Stern Flap And Air Decks
Store/Dinghy Launching Trolleys and Wheels
SKU 00388
£199,00
Swan neck style launching wheels for inflatable boats with extending flaps (TrimTabs) on the transom which make it impractical to fit conventional launch wheels. These heavy-duty wheels are made from Stainless Steel and will swivel when not in use. Fitted with pneumatic tyres to make them suitable for any terrain. Rated up to boat & engines weighing up to 120kg these are perfect for the large Boatworld Air V-Type range with (330 & 380 models) and Orca engines from 9.9hp. They can also be used on other boat types if required.
  • Design for Boats with Trim Tabs
  • Detachable
  • Heavy Duty pneumatic tyres
  • Stainless Steel construction
  • Come with all fittings
  • Suitable for boats & engines set up's weighing up to 120kg.
© Boating Goods Report abuse
