• Boating Goods
Boating Goods
Boating Goods
Boat Trailer Adjustable Winch Post
Store/Boat Trailer Parts
SKU 00309
£85,99
Adjustable boat trailer winch post galvanized finish. The angle of the post is simply determined by the angle in which it is bolted onto the drawbar. It can be set to suit your needs. Comes supplied with an humpback snubber block and all bolts including winch fitting bolts. Maximum size drawbar fitted to is 100 x 50mm
© Boating Goods Report abuse
