• Boating Goods
Boating Goods
Boating Goods
Boat Trailer Bunk Replacement Rollers
Store/Boat Trailer Parts
SKU 00310
£199,99
This boat trailer bunk to rollers conversion kit is designed to replace those hard to launch skids / bunks to easy to launch and load boat trailer rollers roller bunks.
Simple to fit, remove existing boat trailer bunks and replace the bunks with the boat trailer roller carriages, they simply bolt onto your existing upright supports (either 25mm or 30mm)
Non marking polyurethane rollers with nylon inserts, galvanized roller carriages and spindles, comes supplied with all fixing bolts
© Boating Goods Report abuse
