MERCURY® GENERATION II BOAT ENGINE CABLES
› Standard Control Cables have Stainless Steel or Brass Fittings depending upon the type of cable
› Standard Control Cables use SS high performance lubricated inner for smooth operation
› Standard Control Cables have Minimum Bend Radius of 8”
› Standard Control Cables have black outer jacket for effective durability and offer great resistance to UV, Petrol, Fluids & other chemicals.
Mercury Generation 2 Boat Engine Control Cables EC-036-XX (XX is length of cable in feet) are used for Shift and Throttle application. Different designs of Engine Control Cables are used depending on the engine type and installation.
  Multiflex offers a wide variety of Engine Control Cables for different applications. Engineered out of corrosion resistant materials and components these control cables meet or exceed all industry standards.
  Multiflex Mercury Generation 2 Boat Engine Control Cables are interchangeable with most common SeaStar Solutions®, Morse®, Ultraflex® Engine Control Cables.
Applicable for Mercury® Generation II series engines
