Engine Control Cables EEC-005-XX (XX is the length of cable in feet) are used for Shift and Throttle application. Different designs of Engine Control Cables are used depending on the engine type and installation.
Multiflex offers a wide variety of Engine Control Cables for different applications. Engineered out of corrosion-resistant materials and components these control cables meet or exceed all industry standards.
 Multiflex Engine Control Cables are interchangeable with the most common SeaStar Solutions®, Morse®, and Ultraflex® Engine Control Cables.
Refer to the Cross-reference Chart for interchangeability.
Applicable for Mercury® & Mercruiser® Engines
Travel: 97 mm | EDGE Conduit: 8.6 mm | Inner: 2.75 mm (Coated Inner)
