• Boating Goods
Boating Goods
Boating Goods
Mercury® Generation 2 Boat Engine Control Cables
Store/Boat Outboard Control Cables And Boxes
SKU 00491
£34,00
Length
MERCURY® GENERATION II BOAT ENGINE CABLES
› Standard Control Cables have Stainless Steel or Brass Fittings depending upon the type of cable
› Standard Control Cables use SS high performance lubricated inner for smooth operation
› Standard Control Cables have Minimum Bend Radius of 8”
› Standard Control Cables have black outer jacket for effective durability and offer great resistance to UV, Petrol, Fluids & other chemicals.
Mercury Generation 2 Boat Engine Control Cables EC-036-XX (XX is length of cable in feet) are used for Shift and Throttle application. Different designs of Engine Control Cables are used depending on the engine type and installation.
Multiflex offers a wide variety of Engine Control Cables for different applications. Engineered out of corrosion resistant materials and components these control cables meet or exceed all industry standards.
Multiflex Mercury Generation 2 Boat Engine Control Cables are interchangeable with most common SeaStar Solutions®, Morse®, Ultraflex® Engine Control Cables.
Applicable for Mercury® Generation II series engines
Travel : 90 mm | Conduit: 7.0 mm | Inner: 1.9 mm SS-Solid Wire | End Thread: 10-32 UNF
© Boating Goods Report abuse
