Outboard engine trolley with tank shelf to take outboard engines up to 150hp.
The new type wheels will hold up to 300kg.
The outboard trolley main frame is constructed from 27mm galvanized steel 3mm in thickness.
Its an heavy duty trolley, also can be used for an outboard engine workshop stand.
