• Boating Goods
Boating Goods
Boating Goods
Pivoting Boat Trailer Rollers On Poles With Clamps Per Pair
Store/Boat Trailer Parts
SKU 00384
£149,99
We have for sale a pair of four boat trailer rollers on poles with clamps carriages, rollers, stems and clamps to fit all boat trailers. The boat trailer rollers carriages are 300mm long and 40mm x 40mm box section. The roller spindles are 300mm long. The carriages are supported by poles 34mm diameter and 400mm long also fully galvanized. The whole assembly is held by a BZP split clamp which is very easy to adjust in height. Ideal for small boat trailer, jet ski trailers etc. The boat trailer rollers carriages pivot on the upright poles and also the roller spindles pivot to ensure perfect contact with your boat.
You will receive in the kit the following.
8 off boat trailer rollers. 8 off roller spindles. 4 off roller carriages. 2 off 400mm long 34mm diameter poles. 2 off 34mm bzp split clamps.
© Boating Goods Report abuse
