Small Boat Trailer, Dinghy Trailer Has Hot Dipped Galvanized Steel Chassis With Adjustable Length Drawbar. Fitted With Pressed Steel 50mm Ball Towing Hitch.
Weight Is 65kg. Fitted With 350kg Units. Overall Length Is 11’. Width Is 5’.
Dinghy Trailer Is Ideal For Inflatables, Small Ribs, Tenders And Boats.
The Whole Trailer Breaks Down Into Kit For Sending By Carrier Or For Stowing Away At The End Of The Season. A Very Cost Effective Yet Durable Boat Dinghy Trailer. Also Fitted With Boat Trailer Snubbers . Very Lightweight, Can Also Be Used As A Launching Trolley/Trailer.
Wide 30cm Adjustable Side Supports, Adjustable Height Keel Support Bracket That Will Also Adjusts Along The Drawbar.
Single Axle With 400 X 8 4 Ply Wheels And Tyres.
Draw Bar Comes In 2 Parts For Stowing Away When Not In Use.
