• Boating Goods
Boating Goods
Boating Goods
Hand Operated Galley Water Pump
Store/Boat Deck Fittings And Hardware
SKU 00479
£59,99
Water Galley Rocket Hand Pump Faucet is standard equipment on thousands of boats, RVs, and mobile homes. Very practical and has a rocker-action pump, suitable for salt or freshwater. Beautiful stainless-steel finish with an ultra-simple design. Ideal for boats, campers, and RVs.
SPECIFICATIONS:
Self-Priming: Yes
Material: Stainless Steel
Capacity: 60GPH (228LPH)
Dimensions: 5-9/16 inches (141mm) above
Clearance: 4-5/8 inches (117mm) clearance below the counter
Distance between holes: 3-1/16 inches (78mm)
Base Dimensions: 2-7/8 inches (73mm) x 3-5/8 inches (92mm)
Includes: 3/8 inches Barb Connector
© Boating Goods Report abuse
